CONFIGURATIONS
D_7D_7 Member Posts: 12 ✭✭
edited August 2019 in General
i want to create drawing file for a component which has different configurations... for example i create a drawing file for 500mm rod... i changed the length using configuration to 300mm... so what will happen to the drawing file ?
    Nothing - the drawing will remain unchanged. You can right-click a view and select "change configuration" to update it.
  • D_7D_7 Member Posts: 12 ✭✭
    thank you
