when I create a sketch, Onshape will no longer allow me to change dimensions in the sketch.
Eric_Brooks
Eric_Brooks Member Posts: 5 ✭
Have used Onshape for 4 years and have never come across this problem before. Can anyone help me out?
  • bradley_sauln
    bradley_sauln Moderator, Onshape Employees, Developers Posts: 373 image
    @Eric_Brooks Can you please submit a support ticket and share the document with support so we can take a look. Please include details such as which sketch feature you were working on and which branch (if there are multiple) you are working in.
    Twitter: @bradleysauln
    edited August 2019
    @Eric_Brooks - are you definitely editing the sketch? In SolidWorks you can double click a sketch in the graphics area and edit the dimensions - in Onshape you have to right-click the sketch and select Edit or double-click the sketch in the feature list.
    EDIT: Oops, sorry - just saw you have been using for 4 years  :o - can you post the URL to your doc?
  • Eric_Brooks
    Hi Neil I am definitely editing the sketch. When I click on the size a grey box with the same dimension appears beside the blue box and it will not let me change the size. Any ideas would be welcome.
  • konstantin_shiriazdanov
    May it be a driven dimensions?
  • Eric_Brooks
    Hi konstantin, changing from driven makes no difference at all
    URL and sketch name please!
  • Eric_Brooks
    Thanks to all who tried to help me. Problem now solved and had to do with the position of the number lock key which was off.
