Inserting Dates without using Properties
Michael_CoffeeMichael_Coffee Member Posts: 91 ✭✭✭
Is there currently any method of inserting a date into a drawing that does not rely on properties? The only field I see is where you can customize the date format, but nothing about inserting one.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,043 PRO
    edited September 2019
    You can insert the date by creating a note, then chose the drawing properties drop down and select which date you want to reference, based on when it was drawn, edited, or approved
    Not sure of any other way without using the properties that is still auto-updating... Otherwise you just add a note and manually type out the date.
    If the issue is, you want it to display a different date, then you can edit the drawing properties with a handy calendar.
