Sketch plane not appearing
iveta_ivanova
Member Posts: 7 EDU
I only just started the tutorials and I encountered a very very basic problem which I have to sort out before I can progress further:
Since last night when I want to start a sketch, the sketch plane isn't appearing at all. I tried both first choosing a plane and then clicking the sketch button, or vice versa, as well as right-clicking on the plane followed by Create a sketch.
The sketch1 window does appear, but since there is no sketch plane obviously I can't sketch anything.
It worked before so I guess I have pressed something while exploring the software, but because I only just started, I have no idea what it could be.
Any help will be appreciated.
Hi @iveta_ivanova - the planes may be hidden (eye icon next to planes in feature list), but they don't have to be visible for you to sketch. Does the sketch dialog have a plane selected? Do you see "sketch1" in the graphics area? Are the icons active? If yes to all these then you should be able to start sketching.
Senior Director, Technical Services, EMEA0 -
@iveta_ivanova
You may also try hitting 'N' key to give you normal view after starting a sketch. Maybe you are looking at the edge of your sketch plane?www.accuratepattern.com0 -
Hi, thanks for the prompt responses.
No, the icons were not active and yes I am pretty sure that I did select a plane.
When I restarted the whole thing the problem was fixed. If I manage to recreate it again I will take screenshots, sorry I didn't think of doing it this time.0
