How to import and work on dwg file on onshape
anna_pir
anna_pir Member Posts: 14 ✭
Hello
I would like to know how to import and work on dwg file on onshape properly so I can continue to work on it. I have imported it today but the file is coming empty, like I only see the file is imported but there is no preview or anything els to continue the deisgn.
or maybe I should have the file in other format but the dwg, what exatly?
thank u in advance
  • brucebartlett
    Not in yet, but being worked on. Should see it soon.
    At the moment you are limited to import 3d model files only.
