How do I extrude the chamfer on this shaft piece?
I'm trying to extrude an imported shaft.  The flat surface was easy enough to figure out, but now I've got to bring out the chamfer.  Not sure how to do that, please help?
  • Not sure what you are asking? If you want to remove a chamfer you could try Delete Face or Replace Face.
  • Sorry, I don't understand the question. What does "bring out the chamfer" mean?  What is your intent?  To make the shaft longer, shorter, thicker, tapered, plain further up or down the shaft before having a square cross section etc?
    Cheers, Owen S.
    HWM-Water Ltd
  • steve_shubin
    steve_shubin ✭✭✭✭
    edited October 2019
    @s_t920
     Is this what you are trying to do?
