Can Construction Lines be placed at the rear of all other lines?
ProblemSolver
ProblemSolver Member Posts: 15 ✭✭
I use Construction Lines all the time as guidelines, they are generally the first lines that I place in my sketch.
My issue is that when I place a line or part line on top of the Construction Line, and then for whatever reason I need to erase or alter an actual line that has been recently added, then the construction line is always the first to be deleted. Is it possible by default that the Construction Line is always placed at the rear of all other lines?
    Feel free to create an improvement request, but there are likely users who prefer it as it is. Don’t forget you can right click and choose “select other” to get the entity you want.
  • ProblemSolver
    Thanks Neil, I will do a improvement request.
  • ProblemSolver
    Thanks romeograham, I've only been using Onshape for the last 5 months, and was unaware of this feature.
