I cant get the circular pattern to generate a a pattern of an extrusion.
nicholas_wood
Posts: 10 PRO
Hi Larry, Many thanks for the help and video. Got it to work.0
Please post the doc URLSenior Director, Technical Services, EMEA0
If Extrude 3 is extruded as a 'new' part instead of an 'added' feature, then the 'part' circular pattern will complete the function. No idea exactly why.
https://cad.onshape.com/documents/34c9598a11f73a8286a8cf8d/w/ded5298b7975245b7b12bcfd/e/e2685291a8532c131f0de614
Thanks Larry, I tried that and it doesn't0
It seems to work in the posted doc above but I know there's nuances I'm probably missing. I think it has to do with extrude 3 and its relationship with the vertex from sketch 1.
Here's what I found...
http://www.youtube.com/watch?v=BT7kDLYnCeI
Have you tried "Apply per instance"?Senior Director, Technical Services, EMEA0
