Can you export an assembly
henry_feldman
Member Posts: 136 EDU
Is it possible to export an assembly. I imported some parts from another CAD package and added them onto a part of my own items like an incredibly useful function for additive manufacturing (I realize it would be goofy as subtractive function).
Right click the tab at the bottom and select Export.Senior Director, Technical Services, EMEA5
Thanks. I often forget the tab itself is a menu target...0
Oh and tip for whoever searches this in the future, if you don't uncheck the "export as separate objects" you will not get a union (for 3D printing you probably want a union)henry_feldman said:Thanks. I often forget the tab itself is a menu target...0 -
NeilCooke, I ran into a probem with exporting an Assembly as STL. I expected it to be exported as positioned in the assembly but I can see the stl has its Partstudio placements rather than the Assembly placement ( my comment: https://forum.onshape.com/discussion/comment/60673/#Comment_60673).
Can you confirm that please?
henry_feldman did share this experience too?0
