Revolved feature only visible when editing revolve
When the check button on the Revolve 1 edit window is clicked, the sketch used for the revolve is visible, but the revolve result disappears from view..
https://cad.onshape.com/documents/271189896c528a34616e49e0/w/939931ff7028104b68f56756/e/fc844516e3a0c8ab40ac1a5d
Prachi Member, OS Professional Posts: 262 ✭✭✭
When you selected the extrude/remove you included the large face of revolve which covers the revolve completely.5
In this case you can select sketch 2 from the feature list.
Hover over and right click to select other.
Thank you!!
