Revolved feature only visible when editing revolve
john_lombardo
Member Posts: 20 EDU
When the check button on the Revolve 1 edit window is clicked, the sketch used for the revolve is visible, but the revolve result disappears from view..
https://cad.onshape.com/documents/271189896c528a34616e49e0/w/939931ff7028104b68f56756/e/fc844516e3a0c8ab40ac1a5d
When you selected the extrude/remove you included the large face of revolve which covers the revolve completely.5
Got it. Discovered the Opposite direction tool!
Thank you!!0
Thanks! Next question: Is there a better way to select the face of sketch 2? When I am able to select it for the extrude, the extrude goes in the wrong direction (away from the part instead of through it.0
There are other ways.
In this case you can select sketch 2 from the feature list.
Hover over and right click to select other.0 -
OK, selected Sketch 2 from the features list. Then selected "Remove", then "Through All" and the extrude goes the wrong way.0
Thank you!!0
