dxf import to sketch?
scott_caskey
Posts: 55 PRO
Can you import a DXF drawing as a sketch? Convert it to a sketch after you import it? When I import dxf files, they are uneditable.
Yes, import to Onshape, insert into sketch, then project the geometry you want onto the sketch, modify as you wish, then export again.Business Systems and Configuration Controller
HWM-Water Ltd0 -
How do you insert it into a sketch?
Senior Director, Technical Services, EMEA1
The above is not working,This is just not working with Onshape, please let me know how to use it in a sketch! I get it in a TAB but cannot use it to make a part from it
@jannie_smal did you click the help link above? You have to create the sketch first.Senior Director, Technical Services, EMEA0
Hi, I had same problem, in this exactly moment. Was looking a way to solve it and this was i did:
1 - Imported a coreldraw crated .dxf file
2 - RMB on the tab imported and created draw from dxf;
3 - Export drawing to dxf from onshape to a new tab
4 - Imported dxf from current document.
