Is 'Create Selection' inactive on In-context geometry?
bruce_williamsbruce_williams Member, Developers Posts: 842 EDU
edited January 2020 in General
I want to confirm before I put in an IR.
I am looking for this when designing fixtures using huge import model as a 'Master Model'.   I want to avoid copying the part into part studio.
www.accuratepattern.com
  • lanalana Onshape Employees Posts: 757 image
    That is correct. Create Selection does not work for context selections. As a work-around you can make a copy of context body which would become local for that part studio context. Then you can use create selection. Please file the IR.
  • romeograhamromeograham Member, csevp Posts: 741 PRO
    Thanks Bruce for putting in the IR.
    The selection in Context mode is really hard to use. You also can't use the "~" (select other), I don't think.
    @romeograham
    I added the 'select other' to the IR.  Thanks for pointing that out; I had noticed that too and it will be very helpful to get both selection tools.  Please vote on the Improvement Request here.
