Rib issue in learning course - Rib feature includes the top surface of the wall that it extends to.
will_hastings
will_hastings Member Posts: 2 ✭
I am trying to complete lesson 4 of the part design course: building a step using Draft, Shell, and Rib features.  Step 13 requires patterning a rib feature, however, in my part, the feature ends up including the entire top surface of the wall that the rib intersects.
Rib feature includes wall surface:
Result when trying to pattern rib:
  • KatieHuffman
    KatieHuffman Member, Onshape Employees, Developers Posts: 194 image
    I believe you just need to check Apply per instance in the Linear pattern. That way the rib rebuilds correctly for this pattern- basically making each rib longer and filling the the top face of the Step.
