Haw to mate a bearing to flat part (extrusion) “A inch” from edges?
MS_021
Member Posts: 7 PRO
I need to fasten Sleeve Bearing with Two-Bolt Flanges to flat bracket.
What is the workflow?
Hello @MS_021 - can you post a screenshot of what you are trying to do? You may need to add a fasten mate relative to the edge of the flat part, then edit one of the mate connectors to add an offset of 1 inch (create the mate first, then expand the mate in the instance list and edit one of the mate connectors listed below it).
Senior Director, Technical Services, EMEA0 -
Bearing should be mate to the right end of the extrusion.
Thank you.0 -
Thank you0
