Can not get loft tool to work.
kailan_heathkailan_heath Member Posts: 2 EDU
Loft keeps giving me error Loft did not generate: would create self intersecting body. I am trying to loft two profiles together and can not figure out why it won't work.
https://cad.onshape.com/documents/5ce4c2b817c29027624b46f8/w/ae63d4b36a185be4e68dbc57/e/82b840492e9b682d8c189c85
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,059 PRO
    edited April 2020
    I can't see the loft command, please take a screen shot showing the error, or make your document  public so we can edit the feature and take a peek.
    I would guess the problem is you need to match verticies, or create guides. That is a common problem.
  • John_P_DesiletsJohn_P_Desilets Onshape Employees, csevp Posts: 273 image
    Hello @kailan_heath,
    I would try to avoid creating profiles that end at a sharp point. There are different profile option in the database that will produce a rounded edge at the base of the profile. However, if you have a specific profile that you want to use that ends at a point, you can simply sketch a small spline or arc at the end of the profile.
    Here are is an example.
    After adding a spline to the end of each profile the loft feature can be created. Let us know how you make out and good luck!
