How do I get a fillet on a flange?
yvogoette
Member Posts: 2 ✭
Hello
Best Yvo
You should be able to do it.
Following is a sheetmetal part with an extrude that cuts a couple of flanges and I was able to fillet an edge.
Note: The fillet was added after "finishing" the sheet metal part.0 -
Fillet and chamfer can be limited sometimes.
I think this is one of those cases.
You will need to sketch a corner and extrude cut it, or like stephen said, finish sheet metal first.
Unfortunatly the fillet won't show up on the flat pattern if you finish sheet-metal so I tend to use the sketch/exturude->remove method0
