why can i not shell this model?
Hi,
Im trying to make the wall of this model 6mm thick and I can't seem to do it? It worked fine in one that I did the other day so don't know what's wrong.
  • mahir
    There we go! Thanks. I think I found the issue. OS is flaking because on any offset greater than .12, the edges from the triangular shape start to overlap semicircular surface. See below. But if you add a slight radius the problem goes away.
