TRIMMING MULTIPLE ENTITIES AT ONE TIME IN A SKETCH?
elliot
EDU
Is there any solution?
Use the Trim tool and click each segment to remove. There is no click and drag option like in SolidWorks.Senior Director, Technical Services, EMEA0
A little disappointed without this tool for trimming multiple entities at the same time.
IIt is less efficient to click each segment to remove .0 -
In many cases, you shouldn’t need to trim. Just select the areas when extruding.Senior Director, Technical Services, EMEA0
