Is there a way to change fundamental plains from the beginning of a construction at a later phase?
Up to now I were not able to fully understand why there are always the newer parts disappear when you go into a sketch of a former part. I guess it makes sense but I just not get it, and it makes things often difficult.
In my actual Problem I would need to change a fundamental plain with the help of newer points. But this is not possible, is it?
Thanks a lot in advance!
@manuel_grün Move the point before the plain.The tree is like a time line - when you edit some feature then anything after that does not exist yet.5
No. The feature list is history based. If you share your doc URL and what you are trying to do we can show you.Senior Director, Technical Services, EMEA1
Thank you both of you!
