Tolerance Options
Hi All
Is there a way to get + + tolerance on the drawing other than doing it all manual?
Not every dimension is a  + - tolerance .......
Please let me know as soon as possible
    NeilCooke Moderator, Onshape Employees Posts: 6,120 image
    edited June 2020
    You need to put a minus sign in front of the number - probably should be easier to discover. You can't have +0 with this method though.
    EDIT: You can have +0 if you set the value to something like -0.0001 and your tolerance precision is set to 3 DP
