Drawing Sheets Issue
Kestrel2486
Kestrel2486 Member Posts: 1 EDU
I have created a custom drawing from a dwt file I use with AutoCAD, but how do I centralise the border when I print, on the screen it looks OK but it will not print centrally. Any help would be appreciated.
  • PeteYodis
    PeteYodis Moderator, Onshape Employees Posts: 594 image
    @Kestrel2486 I would recommend you follow a very good procedure here:
    Best Practices for Creating Native Onshape Drawing Templates - Onshape Learning Center
    Onshape drawings are not exactly like an AutoCAD drawing created from a DWT.  Generally you will have more predictable and robust behavior if an Onshape drawing generates the template.  You can certainly use DWG/DXF data as the basis for the Onshape template creation process - and that is covered in the resource I listed above.  Let me know if you have more questions.
  • john_mcclary
    john_mcclary Member, Developers Posts: 4,102 PRO
    It could be your printer setting too
