How to copy folder?
ehsan_pazooki
Member Posts: 52 ✭
Hello Guys,
a little question! How can I copy a folder in Onshape? Is there any way?
regards,
Ehsan
Folders cannot be copied - that includes folders on the documents page and folders within a document. If you're using Enterprise, you can clone a project (which is essentially a folder).Senior Director, Technical Services, EMEA0
If you don't see project icons like this on your documents page then you're not using Onshape Enterprise:
If you do, right-click and select Clone Project
EDIT: actually that wouldn't help you anyway because that just clones the project users and permissions, not the contents.Senior Director, Technical Services, EMEA0
