Sketch "Use" in featurescript
gauthier_östervall
Member Posts: 99 ✭✭
I cannot find the function to "Use (Project/Convert)" an existing face (which the feature user would define), onto a sketch that I create in my featurescript.
Is it not implemented, or am I just failing at finding it?
Sketch "use" is not available as a FeatureScript function. "Use" when modeling interactively acts to create individual lines, arcs, ellipses, splines, etc as needed so the interactive user has control of those individual entities.
Let use know the larger problem being solved and there is possibly an alternative solution, like using the existing entity as-is, or splitting that entity with a plane and using the split edge.0 -
You can use Project(plane, point) to project edge points onto a plane. the finer the parameters passed to evEdgeTangentLines, the finer the points will be on the plane. The curvature of the result opFitSpline from these projected points is not as good as you will get using the "Use" function, but it works.
so desired edge call
evEdgeTangentLines
project the line origins returned from evEdgeTangentLines to the desired plane.
opFitSpline on the projected points.
Result. spline on plane created.
If the edge loops back on itself, it will fail and you will need to find out why.
Imagine a circle perpendicular to a plane. when you project that circle, you will get points that overlap as it is visibly a line when looking from the plane.
Thanks. I still think that a feature could have a use for "Use" with e.g. a face provided by the user.kevin_o_toole_1 said:Sketch "use" is not available as a FeatureScript function. "Use" when modeling interactively acts to create individual lines, arcs, ellipses, splines, etc as needed so the interactive user has control of those individual entities.
As you described, I ended up extruding a face, and splitting with the sketch plane. Not as elegant, but it does the job.0 -
@kevin_o_toole_1 is it by now possible to create a sketch via feature script with "USE"? That would be extremely helpful for my project.
