Auto-fill file properties
matt_austin
Member Posts: 1 PRO
Hello, does anyone know a way to auto fill the file properties and thus the title block using the partname? Using solidworks I created a macro that would extract part number and name from the filename.
You can create a FS to do that, like the Beam FS
Here is an example with our customized Beam FS
https://forum.onshape.com/discussion/10840/beams-or-weldment-profiles-workflow
There are several examples of FS like this one
https://cad.onshape.com/documents/a297841edd882462faee05d4/w/f3babbcc0eadcd8c83113e90/e/7f5dd1daba845bdf72a1f7e3
Un saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común0 -
@matt_austin
In the drawing title block, you can change the title block to instead use description and part number. You can then fill them out from the assembly BOM or in the part studio properties0
