Standard notes and tables in drawings.
LKRENZLER
LKRENZLER Member Posts: 30 ✭✭
We have a number if standard notes and tables we sometimes use (but not always).  Is there any way to include these in the drawing template or save/copy them from somewhere so we don't have to continually re-create them?  I haven't found an easy solution yet.  Thanks for any help.
  • PeteYodis
    PeteYodis Moderator, Onshape Employees Posts: 594 image
    edited September 2020
    @LKRENZLER I created a support ticket and will tie you to an improvement for a "block library" which will cover collections of drawing information that can be inserted and rely on our versioning mechanism for updates.
    For today, users place standard notes on their drawing templates and then remove them on newly spawned drawings from the templates  - if they don't need them on that particular drawing.
    I would probably make sure to "Move to" those notes and tables onto the title block, as most are located next to title blocks on drawings and this will also ensure they move along with the title block on sheet size change operations.
    This is the best complete reference for constructing custom templates in Onshape:  Best Practices for Creating Native Onshape Drawing Templates - Onshape Learning Center
  • LKRENZLER
    Thanks Pete.
  • ry_gb
    ry_gb Member, csevp, pcbaevp Posts: 275 PRO
    @PeteYodis is this still in the IR backlog or has this been implemented?
    Ramon Yip | glassboard.com
  • PeteYodis
    @ry_gb A block library has not be implement yet. I've created a support ticket for you.
  • Frank_Bertucci
    Frank_Bertucci Member Posts: 16 ✭✭
    Any update on this? Big need for us.
    S1mon Member Posts: 4,636 PRO
    @PeteYodis Add me to the support ticket, please.
  • Jordan_Karyanto
    Jordan_Karyanto Member Posts: 2 ✭
    Has this been resolved yet? Please add me to the ticket as well.
