DXF is not an option when I choose export. Why not?
I am using the free version, if that matters. I am trying to assign a project to my students and we are planning to produce the indivual parts on a laser cutter (CorelDraw), which can use a dxf file.
You can export drawings as dxf.
www.accuratepattern.com0 -
You can also right click on planar part faces and sketches to export those as dxf.
Learn more about exporting here: https://cad.onshape.com/help/Content/exporting-files.htm
You can also check out this older forum post: https://forum.onshape.com/discussion/6072/exporting-simple-dwg-dxf-model-for-laser-cutting
