Third angle default
david_hollis
Member Posts: 2 ✭✭
Is it possible to add the setting of the projection type in the work space tab where we change to metric. Maybe even a choice that says Australian standards
Projection type is set in drawings only - 1st angle for ISO templates, 3rd angle for ANSISenior Director, Technical Services, EMEA0
I need A3 size with 3rd Angle. ANSI doesn't do A3, and ISO doesn't do 3rd Angle0
You can set the projection angle once the drawing is created (right-click to see sheet properties) or you can create your own template.Senior Director, Technical Services, EMEA0
But the Symbol in the title block doesn't change!NeilCooke said:You can set the projection angle once the drawing is created (right-click to see sheet properties) or you can create your own template.0 -
True - you still have to change the template.robert_paynter531 said:
But the Symbol in the title block doesn't change!NeilCooke said:You can set the projection angle once the drawing is created (right-click to see sheet properties) or you can create your own template.Senior Director, Technical Services, EMEA0 -
Yeah this is actually quite a bugbear for Australian and NZ users; we used ISO standards for most things, but generally use third-angle projection.
I see we can manually override it in the Drawing Properties as well
1
