Is there a way to expand the dimension text box?
MikeysMindscape
Member Posts: 2 ✭
As seen in the image below, it becomes cumbersome to enter and edit long equations in the dialog box that opens when you click on a dimension. If you hover you can see the full length of the equation. Is there a setting to make that dialog box bigger? Seems like something that should already just be bigger.
2
Not yet.
There are request out there for this feature. Until then you will need to write it out in notepad and paste it in..0 -
Looking for this improvement as well.
has this been addressed? looking for a solution in 2026
