Extrude part
lukas_lukas768
lukas_lukas768 Member Posts: 7 ✭✭
edited November 2020 in Community Support
I need advice. I'm new in 3d modeling and so is onshape. I'm learning on my own. I downloaded the feeder model from the thingiverse and I want to modify it a bit for myself.
I took the STL file to import it into onshape based on this video I copied the lines of the original model.
Video
https://www.youtube.com/watch?v=b9K5f6zzb1k&ab_channel=JasonHitesman
Using the Line, 3 point arc tools, I created the interior of the model as you can see in the picture. Now I need to extrude it to keep it all on the surface, but I can't extrude.In the middle I have already modeled a cylinder in which there will be food for birds.
Thank you for your help and I apologize for my English.
  • john_mcclary
    If you also draw the inner circle in the sketch it will extrude everything but the inner circle, like you want
    You can also insert your images  in your post rather than uploading them to a 3rd party site :)
  • lukas_lukas768
    Thanks for help. But what you show me in the gif image I know how to do hole in the middle.
    But I can't extrude the object you are doing hole in the middle.
    I fix that use fill function. But how you creat this gif ?
