Insert Positioned into Assembly
famadorian
famadorian Member Posts: 390 ✭✭✭
When inserting into assembly, is there any way to insert it, the way it was intended, from the parts studio?;)
Like in this example, there are 75 surfaces in the part studio. I have to manually position them or is there a smarter way to insert them?
Also, how can I select all 75 at once and insert?
From this document: https://cad.onshape.com/documents/7cc2144342bbe3a40d7400da/w/d0b3f715656ef923093e8116/e/7b546e4f5c12235612c568f6
    Pressing the checkmark on the insert dialog will position the parts relative to the assembly origin. Create a composite part in the Part Studio for all your surfaces.
