How can i get the section view in a drawing without having the default vews on the sheet?
I am having trouble in getting the Full section view of my part in a drawing. I do not want to have the default view (and then use section tool to get an additional section view) for the same. if anyone got the solution kindly let me know.
    NeilCooke Moderator, Onshape Employees Posts: 6,097 image
    There has to be a parent view to determine where the section line is. You can either create the parent view off to the side so it's not in the "printable area" or create your views on sheet 2 and move the section view to sheet 1.
