Removing segments from a sphere
roger_johnston
Member Posts: 3 ✭
I’m a newbie; how do I remove two intersecting segments from a sphere, similar to an Xbox logo. I can make a sphere with a segment missing by revolving a semicircular arc less than 360 degrees, but this won’t work to add the perpendicularly placed second removed segment. Any solutions?
Hi @roger_johnston - not sure where the problem lies? You can either repeat your segment removing process but on a plane perpendicular to the first, or you can use the circular pattern feature to copy it any number of times around the sphere.
Senior Director, Technical Services, EMEA0
Senior Director, Technical Services, EMEA0 -
Thanks - it pointed me in the direction to solve it0
