Enclose and fill not working
zain_ali
Member Posts: 3 ✭
I am trying to create a solid with a bunch of sketches, I filled my sketches and tried to use enclose to turn them into a solid but I can't seem to make it work, I also tried to use the fill command to try and create my solid to no avail. The error from the Enclose was Boolean operation failed to return a valid part. any help would be appreciated. here is the link to my project https://cad.onshape.com/documents/314f7a96929dd83994250cdd/w/ca24e1607b918ad80367cb04/e/f0e0b97483153e071b4a2e67
The two sharp corners (degenerate points that go to an infinitely small size) are the culprit - think about how you would manufacture this? Can it be adjusted?Senior Director, Technical Services, EMEA0
I fixed this by cutting the corners off and making really small surfaces at that point. thank you for your help0
