Can someone point out what i did wrong?
james_webb_sosa
Member Posts: 5 ✭
In the instructions, it says to change the dimensions of the master sketch which I did, but my large arm grip connected itself which is not supposed to happen.
https://cad.onshape.com/documents/c2a82e27351cc6f6f2fc9749/w/44681bf8fcc64c2503c0ca12/e/54564edf141dad173f1c42ad
https://cad.onshape.com/documents/c2a82e27351cc6f6f2fc9749/w/44681bf8fcc64c2503c0ca12/e/54564edf141dad173f1c42ad 0
Edit the extrude that makes the grip and change it to "New" instead of "Add" (probably - your link is not found)Senior Director, Technical Services, EMEA0
I'll see if I can find it.
I apologize for the link maybe this might work
Still not found - is it public?Senior Director, Technical Services, EMEA0
I made it public now hopefully it works
If the two grip sketches are overlapping (as they are now) then using 1 extrude feature will make 1 solid - make it in 2 separate extrude features (one for each grip) and make sure the extrude is set to "New". Or better still -make sure the sketches are not overlapping.Senior Director, Technical Services, EMEA0
