I need help animating a train around a track.
owen_wright015
EDU
I am making a PLTW Train in Onshape and need help running it around the track. Here is a link. https://cad.onshape.com/documents/c1426e6a74739e5b840fefd2/w/9a6a503e33f9812ef61f2123/e/1c575ea47a3320ad676b4b75
The link you provided no longer works. Do you still need help with this?
RENDERCAD
rendercad.ai - Photorealistic product rendering.
________________________________________________________________________1 -
https://cad.onshape.com/documents/b14a24bd1ef34b72d25d6806/w/35d746f2f1cb8cb813e7ca2b/e/40d4212c1879676f5e315c5e Heres the new link i have a slider already in place but my problem is with the Rack and Pinion, it goes way to far when i put in the distance per revolution which should be 7.07. It also wont properly animate with this dimension.
MichaelPascoe said:The link you provided no longer works. Do you still need help with this? Yes please.
Sorry for the late response. The project is probably solved or finished by now, but here is what I would do:
When I animate parts along a path, I usually try to constrain the part to a single surface with no breaks (An example is posted here). This makes it easier, but may not have the distance per revolution you are looking for.
RENDERCAD
________________________________________________________________________0
