Query about linear pattern of rib in step excercise
When I try to do linear pattern of the rib as done in slide 13 of step exercise, the linear pattern wants to make the pattern of the rib along with the edge of the step instead of just patterning the rib. I guess it's because of merging the rib with the step part. It would be very helpful is someone can help in pointing out my mistake. Thanks a lot in advance!
https://sso.onshape.com/documents/7ab169d7d45ba88bf4e76878/w/6de92cccd6e80e0a7828b417/e/c9c852ebce6d97f71369e384
  • Hi, I had the same situation. You have to check the Apply per instance box, if I understood your problem correctly.
  • troy_alton
    troy_alton Posts: 6 PRO
    I'm having the exact same problem, however I do not have the "Apply per instance" checkmark box as an option at all.
    NeilCooke Posts: 6,097 image
    It's called "Reapply features" now.
