sweep sketch along your own floor how?
mko_sc
mko_sc Member Posts: 27 PRO
hy
after a sketched "opExtrude"
how is it possible to sweep the resulting closed sketch along a coordinate of its plane?
to get this?
thank you
    The result is a planar sketch? It is not possible to sweep a profile like this because it would self-intersect. You would have to determine the end result yourself and construct it as a sketch in FeatureScript. General rule: if you can model it using the standard features then you can construct it with FS.
