Bend relief not needed
ZeroDarkBirdyZeroDarkBirdy Member Posts: 3 PRO
Is there a way to remove the relief from this bend? I do not need it here and I can't seem to get rid of it.
Here are my current settings.
Any help will be greatly appreciated.
Thank you!
  • wayne_sauderwayne_sauder Member, csevp Posts: 664 PRO
    Try changing your bend relief type to a tear.
  • lanalana Onshape Employees Posts: 770 image
    If you over-build your model and then use cut in flat to trim it, there'll be no relief
Howdy, Stranger!
