Can I use a variable in the quantity field of a circular pattern ?
brian_sweet
Member Posts: 12 ✭
I have a sketch, and am using a circular pattern. I have diameter variable for the size of the ring. Depending on the size of the ring I may want to increase/decrease the count of the pillars on it.
I have created a variable name #Num_Bars as a number but it will not accept it.
Not possible. This should be done using a feature pattern.Senior Director, Technical Services, EMEA0
I will git that a try
