Older Documents
johan_rutten
Member Posts: 5 EDU
Hello, i have a little problem with my documents. Iff i open one document that i made last year like 4 months ago, i can't make any ajustments now.
Can someone tell me what the problem can be?
Hi Johan, we need more information to be able to help you (see https://forum.onshape.com/discussion/9107/forum-post-checklist-read-this-first) -- at least a link to the document and a screenshot of what you're seeing when you try to make a change.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc0
Is it possible that the document is private, but you are now using a free account? In this case make the document public in order to be able to modify it.0
The document has an EDU marker. You're on a free account. Was it made by a different account? (I can't tell since there's no link to the document) To modify it with a free account, you have to make it public. If the document is owned by a different account, that may only be doable from that account.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc0
edu accounts expire on some periodicity and are converted to free account. If you are still at school, you should be able to renew your edu account. see this post https://forum.onshape.com/discussion/comment/59532/#Comment_595320
Hello, here is a picture of a document that made a few months ago. as you can see i can't make any adjustments anymore. Can i change this document to an other status en how can i do this?
Hello, Thanks for answering my question. It solved my problem.0
@johan_rutten
How do you get the language in Dutch????0
