Can one control the time to automatic logout?
tony_gtony_g Member Posts: 23 ✭✭
Is there a way to specify how long an inactivity while logged in will automatically require a new login?  It happens too often to my taste, but could not find such a setting in my account/security settings...
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,041 PRO
    No, but it should be about an hour without activity.
    If you want to fake activity or prevent an log out on an open tab, you can select a face of any part. that will send a signal to the Onshape server which resets the idle timer.
    Sometimes you may see an early log out, even if you are currently working. that is usually summed up as an internet connection issue, or a browser crash.
  • tony_gtony_g Member Posts: 23 ✭✭
    Thanks, John. I like the highlighted face trick and will try it!  :-)
  • john_rousseaujohn_rousseau Member, Onshape Employees, Developers Posts: 421 image
    The system is designed to log you out after 4 hours of inactivity. Open documents will close after 1 hour of inactivity. If you are seeing shorter times than that, please open a support ticket.
    John Rousseau / VP, Technical Operations / Onshape Inc.
  • a00ba00b Member Posts: 4
    John, do you think it is reasonable to log out after 4 hours?
