Moving Part Studios to another document
jmccormick
jmccormick Member Posts: 40 ✭
As I try to figure out how I want our Onshape to be organized, I have created several Part Studios that I now realize should be in some sort of Standard location that can be shared by any future project (document).  I have these in a folder within the existing project (document) but there is no option to move those folders to another document.  I feel this would be a good choice so that others will know where to go to find the specific shared object rather than searching through all existing documents to see if it is available.
I am not so far along that I couldn't delete them and re-import them but I was hoping there is a better way since the objects are already used in assemblies with configurations and deleting them would break the assembly and configurations.
  • Prachi
    Prachi Member, OS Professional Posts: 262 ✭✭✭
    edited April 2021 Answer ✓
    You can move part studios and assemblies etc to a new document. Right click on selection as shown in clip and select move to document or new document. The documents can then be moved to any folder you wish for organizing.
  • Prachi
  • Gerard_at_Rex
    Gerard_at_Rex Member Posts: 2 ✭
    None of above works. Right-click on a selected tab or part does not offer a move option. Nor a copy, so I could paste it into a new document. What am I overlooking?
    S1mon Member Posts: 4,613 PRO
    @Gerard_at_Rex
    Are you looking at a version or an active workspace? I don’t think this works if it’s a version.
  • skottmorris
    skottmorris Member Posts: 3 EDU
    Try doing this from the Tab bar in the two documents.
    - Right mouse button click on the desired part studio tab in the tab bar and choose Copy to Clipboard
    - Navigate to the desired Document and click the + button in the tab bar and choose Paste Tab
