Circular pattern Problem
nicola_malagnini
Posts: 35 EDU
hi,
as you can see in the video. there is a problem. when i try to do a circular pattern of a hole, i can't extrude holes that results. and the hole that i extrude before, now is full.
where is the problem?
https://youtu.be/DxXpVnZ3wtI
thanks
thanks
Change it to Feature Pattern (currently set to Part Pattern)Senior Director, Technical Services, EMEA0
Solved!
Thanks!0
