Loft Exercise - Mass does not match
ed_o_connor101
ed_o_connor101 Member Posts: 2 EDU
I'm doing Part Design Using Part Studios
In the loft exercise I can't find my mistake.
https://cad.onshape.com/documents/68c024ada82f59756dda57cb/w/7cbc72176c0624276e6260e7/e/17615deea1e4e7b479879d38
The correct mass for the loft is  314.212 g
After checking everything, I keep getting 333.916 g.
The volume is larger too. Why the discrepancy?
  • Ste_Wilson
    Ste_Wilson Member Posts: 691 EDU
    I mostly ignore the end question, I figure it's about the journey, not the destination! :)  If you want cleverer people than I to have a poke at your model you need to make it public.
  • KatieHuffman
    KatieHuffman Member, Onshape Employees, Developers Posts: 194 image
    @ed_o_connor101
    I took a look and I think at least part of the problem is your bottom profile sketch. The 40mm is between the virtual sharps like this:
    But yours looks like this:
    If that doesn't fix it- check some of your other dimensions too. Also at the end of the self-check quiz we provide a link to a completed model to check against.
    I agree with @Ste_Wilson its about the journey- but validating the experience is nice too!
