Beams FeatureScript since V21 merge failing unless Properties are set
andyshinn
andyshinn Member Posts: 7 PRO
Not sure if this is a bug in Beams FeatureScript. But it fails for merge sections unless properties are set. Intentional or bug?
    That would be a bug. Thanks for letting us know.
    Thanks, @andyshinn it is now fixed in V25. Looks like that bug has been there for a good while. Also took the opportunity to optimise more parts of the code to improve performance.
