can you change the color of the planes
I was wondering if you can change the colour of the planes and text seeing as I find some blues very difficult to see?
  • aholmes
    aholmes Member, Onshape Employees Posts: 7 image
    Hi Jade, I'm from our User Experience team. You can't change the color at the moment, but what would you want to change the color to if you could? Are there other parts of Onshape that you find difficult to see?
  • aholmes
  • jade_easton
    jade_easton Member Posts: 4 ✭
    Hello, If I could I would want to change it to red. The only other part of Onshape that is kinda difficult to see is the blue on the sketch tools. Thank you so much for the response :smile:
  • aholmes
    Thanks Jade! Is there a reason for red? Better contrast or personal preference?
  • Matthew_Curran
    Matthew_Curran Member, csevp Posts: 25 PRO
    Hi Jade, while I don't think this is the best solution, it might be helpful until accessibility options are added into Onshape. I found an extension for chrome that is supposed to help with different colorblindness.
    https://forum.onshape.com/discussion/16771/can-you-change-the-color-of-the-planes
    The most effective option I found was the Blue-Blind / Tritanopia setting that changed all blue colors in Onshape to a greenish color. See image below.
