How to show lines from sketch in 2D drawing
Dear community members,
I hope that you can solve my problem.
I've constructed a circular base, that should be cutted afterwards by a laser cutter. At this base I've sketched a center line and two rectangles that should be engraved by the laser also.
If I add the 2D drawing for exporting the SVG the line and the rectangles are'nt visible and the exported SVG also doesn't show these elements.
Would be nice if you would have any solutions or suggestions.
Kind regards,
Günter
    Right-click view > show/hide > show/hide sketches
  • günter_nimmerfall
    günter_nimmerfall Member Posts: 7 EDU
    Hello Neil,
    thank your for your help. It works like a charm!!!
