My Sketch tools disappear.
When I add a sketch, the sketch tools appears. Everything is locked until I check the check box, then all the tools disappears and replaced with a new set of tools I have never seen before. PS you gave no direction on how to change the units. That took 30 minutes.
    When you created your account it asked you what units you want. Everything you need to know is here: https://learn.onshape.com
  • bruce_williams
    on your first point - complete your sketching THEN hit the green check to confirm you are done with sketch for now.
    www.accuratepattern.com
