Why doesn't my hole callout display hole depth on a custom hole?
Tony_Bauccio
Tony_Bauccio Member Posts: 2 ✭
edited December 2021 in Community Support
I have created a simple, blind, custom hole using the hole feature for my part.  When dimensioning the hole with the hole callout on a drawing, it does not display the hole depth after the diameter.  I tried changing the start point with the "Start from Sketch Plane" option and with it selected or not, the hole depth still doesn't appear.  Is there a way to fix this or is this functionality not built into OnShape?
  • Daniel_Aldrich
    Daniel_Aldrich Member Posts: 4 ✭✭
    I tried this myself, and was not able to recreate the issue.
    For me, using a custom hole, it showed the depth after the diameter just as in your second Image... I would make sure you are using the hole callout and not the dimension tool in your drawing.
